[GRASS5] Gmakefiles - $(VECTLIB) question
Markus Neteler neteler at geog.uni-hannover.de
Thu Jan 4 04:27:10 EST 2001
On Thu, Jan 04, 2001 at 03:24:29PM +0700, Justin Hickey wrote:
> Hi Markus
> Markus Neteler wrote:
> > still I think that such double call is unusual (maybe I am wrong and
> > it's common). I have been posting this here to indicate that *maybe*
> > something referenced incorrectly within GRASS vector libs.
> > If you think that's o.k. then I will keep these double entries. Is
> > that documented somewhere?
> It is definitely unusual, and the module did compile before. Look at
> what has changed since the last version of the Gmakefile to see what is
> causing the problem. Maybe we can get a hint from that.
Well, Radim had to use a similar trick:
$(CC) $(LDFLAGS) -o $@ $(LIST) $(VECTLIB) ... $(VECTLIB_REAL) $(DIG2LIB) ...
So that's even not what it should be.
> BTW, I am currently changing all Gmakefiles that have VASK. VASK was
> basically $VASKLIB $CURSES, and $CURSES was some -l stuff (eg -lncurses)
> so I deleted VASK from make.mid and am changing all VASK references to
> VASKLIB and adding CURSES to the compile line (just before MATHLIB).
Yes, that's the correct way. Thanks for doing this job,
 Markus
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
