[GRASS5] instructions for making binaries
mlennert at ulb.ac.be mlennert at ulb.ac.be
Wed May 23 11:20:56 EDT 2001
> > BTW, I get a warning at the very end of the compile process:
> > cp: cannot stat `src/scripts/shells/create_ipcs.sh': Aucun fichier ou
> > répertoire de ce type
> > chmod: getting attributes of `/home/grass/grass5.0.0pre1/dist.i686-pc-linux-gnu
> > /dev/create_ipcs.sh': Aucun fichier ou répertoire de ce type
> > This doesn't seem to cause a problem up to now, but what does this mean ?
> Mhhh. It shouldn't appear any more as create_ipcs.sh is removed and all
> cp's as well. Somewhere we probably missed to remove it. When does it
> appear?
Right before the message about a successful compilation. Nothing is mentioned in the error.log.
Moritz
