[GRASS5] instructions for making binaries
mlennert at ulb.ac.be mlennert at ulb.ac.be
Wed May 23 11:49:36 EDT 2001
> Hi again,
> On Wed, May 23, 2001 at 04:46:44PM +0100, Markus Neteler wrote:
> > > cp: cannot stat `src/scripts/shells/create_ipcs.sh': Aucun fichier ou
> > > répertoire de ce type
> > > chmod: getting attributes of `/home/grass/grass5.0.0pre1/dist.i686-pc-linux-gnu
> > > /dev/create_ipcs.sh': Aucun fichier ou répertoire de ce type
> > > This doesn't seem to cause a problem up to now, but what does this mean ?
> > Mhhh. It shouldn't appear any more as create_ipcs.sh is removed and all
> > cp's as well. Somewhere we probably missed to remove it. When does it
> > appear?
> o.k, I found it:
> ./src/CMD/generic/POST_INSTALL.sh
> and have removed it. Glynn, shall we keep the create_fifos.sh there?
> Moritz: Does it break the installation? Then we have to release pre2...
> If it is just a warning, we can live with that.
It doesn't seem to cause any problems up to now. I'm testing right now. d.rast
works well here (no speed or system resources problems), so does nviz,
apparently.
Maybe we should put up a list of modules that we can use as a test suite.
Preferably with a specific test data set. I don't even know most of the GRASS
modules, and so a list of mission critical modules to test would be good.
I'll make the binaries and ftp them in so that others can test them.
Moritz
