[GRASS5] instructions for making binaries
Glynn Clements glynn.clements at virgin.net
Wed May 23 13:12:46 EDT 2001
Markus Neteler wrote:
> > > cp: cannot stat `src/scripts/shells/create_ipcs.sh': Aucun fichier ou
> > > répertoire de ce type
> > > chmod: getting attributes of `/home/grass/grass5.0.0pre1/dist.i686-pc-linux-gnu
> > > /dev/create_ipcs.sh': Aucun fichier ou répertoire de ce type
> > > This doesn't seem to cause a problem up to now, but what does this mean ?
> > Mhhh. It shouldn't appear any more as create_ipcs.sh is removed and all
> > cp's as well. Somewhere we probably missed to remove it. When does it
> > appear?
> o.k, I found it:
> ./src/CMD/generic/POST_INSTALL.sh
> and have removed it. Glynn, shall we keep the create_fifos.sh there?
Ideally the FIFOs would be created by "make install", but only if
GRASS was configured with "--with-fifo".
Failing that, create_fifos.sh should probably remain so long as GRASS
supports FIFOs.
An alternative would be to have the driver create the FIFOs at
startup, using the same naming convention as with sockets.
Glynn Clements <glynn.clements at virgin.net>
