[GRASS5] file ownership after installation
Hal Mueller hal at seanet.com
Fri Oct 19 20:53:16 EDT 2001
At 9:06 AM -0600 10/19/01, Roger Miller wrote:
>I don't know of anything in the GRASS5.0 distribution that needs to be
>owned by root to work correctly.  I think in most systems if something
>doesn't need to be owned by root, then it shouldn't be owned by root.
I don't understand this--I thought the purpose of root was to own the
system, so that individual users can't tamper.
>In my setup (Linux 2.4) the /usr/local/grass5 directory itself is owned by
>root and users have only read and execute access to anything in the tree.
>As a result, the source is protected from tampering, even by the
>unpriviledged user who owns the files.
Who is the owner of the files?  What stops that owner from
inadvertently damaging the directory?
I can't recall any Unix system I've ever worked on where root
_didn't_ routinely own the system and addon software.
