[GRASS5] d.legend updates
H. Bowman ihatejunkyabastards at yahoo.com
Wed Dec 4 18:41:44 EST 2002
> >   -The G_fatal_error -> exit(-1) was the only bug fix I missed verus
> >   the CVS version.
> This appears to be erroneous; what was your reason for this change?
It is. I was a bit braindead when I looked at the rev 1.6 -> 1.7 diff.
The comedy of errors continues..
> >   -The dots_per_line-5 fix makes the output look much better.
> I think that I see what you're trying to do, but I don't think that
> the fix is quite right (all sides should be equal length).  I've
> applied the attached patch instead.
Yes, that's a better solution.
I see what is in CVS now has the maxfontsize= and -o enhancements. If
they will both be depreciated in the following version, is this really wanted?
Someone might want to back out the src/tcltkgrass/module/d.legend change
as well.
