[GRASS5] Next steps for GRASS
Michel Wurtz mw at teledetection.fr
Mon Jan 7 12:34:10 EST 2002
Bernhard Reiter wrote:
> On Mon, Jan 07, 2002 at 03:05:08PM +0000, Michel Wurtz wrote:
> > Does this mean that I should do that on "MAIN" and must only fix
> > bugs on release_branch ?
> That is the idea.
> As it obviously did not happen as envisioned,
> we have to do the merge first,
> before we can branch again.
How to merge ? should I create another grasss directory for that and
copy all my changes in it, then check-in ?
I believe that simply changing the tag will only replace all the files
in release_branch by the one in main trunk... I don't want to loose
the modification I've not uploaded until now !
Michel WURTZ - DIG - Maison de la télédétection
               500, rue J.F. Breton
               34093 MONTPELLIER Cedex 5
