[GRASS5] Next steps for GRASS
Bernhard Reiter bernhard at intevation.de
Mon Jan 7 11:13:31 EST 2002
On Mon, Jan 07, 2002 at 03:05:08PM +0000, Michel Wurtz wrote:
> Markus Neteler wrote:
> > Then: An outcome of the developers meeting in Trento last November
> > was that a merge back of the release_branch into the experimental
> > tree is required for synchronization. However, from there we will
> > create a new release_branch again which only contains the modules
> > intented for release as stable version.
> I'm a little confused by release branch and main trunk of Grass5.0.
> I made all the changes (bug fixes and some code enhancement) on the
> branch "releasebranch_11_april_2001_5_0_0".
A lot of people did, you are not alone... :)
Another stragety was not explained enough.
> Does this mean that I should do that on "MAIN" and must only fix
> bugs on release_branch ?
That is the idea.
As it obviously did not happen as envisioned,
we have to do the merge first,
before we can branch again.
If you think about a code change, which is
	Completly experimental and not of immediate relevance:
		Consider adding it to grass51
	If a critical bug: consider release branch
			   Ask Markus.
	Default: MAIN
Bernhard
Professional Service around Free Software                (intevation.net)
The FreeGIS Project                                         (freegis.org)
Association for a Free Informational Infrastructure            (ffii.org)
FSF Europe                                            	  (fsfeurope.org)
Name: not available
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20020107/3f947c36/attachment.bin
