[GRASS5] Newbee problem starting grass5 on Win2K
Kenneth Cabrera krcabrer at perseus.unalmed.edu.co
Fri Jan 18 14:00:35 EST 2002
I install cygwin, XFree86 and GRASS 5.0 precompiled
When I start grass5 with the followin command
/usr/local/bin/grass5
The first screen is this:
 WELCOME TO GRASS          Version 5.0.0pre2    September 2001
1) Have at ....
2) When working on your ...
3) Check the GRASS webpage for feedback...
Hit RETURN to continue
Then when I hit RETURN, the following message apears:
Error opening terminal: xterm.
Invalid resource file, removing /administrator/.grassrc5
administrator at SIG ~
What am I doing wrong?
if I type xterm... it works fine.....
Thank you for your help
Kenneth Cabrera
Universidad Nacional de Colombia
Sede Medellin
