Kenneth Cabrera wrote: > Then when I hit RETURN, the following message apears: > > Error opening terminal: xterm. This means that xterm's terminfo file can't be located (it should exist as /usr/share/terminfo/x/xterm). Ensure that you have installed the "terminfo" package. -- Glynn Clements <glynn.clements at virgin.net>
