[GRASS5] Re: [GRASSLIST:3916] Re: Grass5.0.0pre4 Installation Problems(cont.)
Rainer Trusch rainer.trusch at students.uni-mainz.de
Thu Jun 20 12:40:33 EDT 2002
Hi Glynn,
I had the problem with not compiled modules as well with gcc
3.0.4. Using 2.95 worked fine. It looks like 2.96 and 3.0.4 have
problems compiling GRASS, because these Versions were mentioned in
many mails about this problem. This should be checked out, because
it's just an observation, but I can't prove it.
Rainer
On Thu, 20 Jun 2002, Glynn Clements wrote:
> [CC'd to GRASS developers' list.]
> Neil.Murphy at axa.ie wrote:
>> Here is the result from  gmake5 src/libes/edit".
>>  In function `format_value': edit_cellhd.c:112: Internal compiler
>> error in subst_stack_regs_pat, at reg-stack.c: 1414Please submit a
>> full bug report.  See <URL:https://qa.mandrakesoft.com/> for
>> instructions.
> This exact same message has been reported before, in:
> 	From: "Georges Schwob"<schwob at respublica.fr> Subject:
> [GRASSLIST:3697] Re: Compile Grass5.0.0pre4 Date: Tue, 21 May 2002
> 14:52:58 +0200 Message-Id:
> <GWGP4A$59DCDBBBEE9974BC403CD984877FA5A9 at respublica.fr>
> He reported that "gcc -v" said:
> 	Reading specs from
> /usr/lib/gcc-lib/i586-mandrake-linux-gnu/2.96/specs gcc version 2.96
> 20000731 (Mandrake Linux 8.2 2.96-0.76mdk)
> Presumably this is the one from the Mandrake 8.2 CD?
> You may need to replace your copy of gcc with an updated version.
> However, another poster reported success on Mandrake 8.2 with:
> 	CFLAGS="-O3 -mcpu=pentiumpro -Wall" LDFLAGS="-s" ./configure
