[GRASS5] Re: [GRASSLIST:3916] Re: Grass5.0.0pre4 Installation Problems(cont.)
Morten Hulden morten at ngb.se
Fri Jun 28 12:29:44 EDT 2002
On Thu, 20 Jun 2002, Glynn Clements wrote:
> Neil.Murphy at axa.ie wrote:
> > Here is the result from  gmake5 src/libes/edit".
> >  In function `format_value':
> > edit_cellhd.c:112: Internal compiler error in subst_stack_regs_pat, at
> > reg-stack.c:
> > 1414Please submit a full bug report.
> 	CFLAGS="-O3 -mcpu=pentiumpro -Wall" LDFLAGS="-s" ./configure ...
Yes, seems to be the -O flag
src/libes/edit fails with -O2, works with -O3
tested on HEAD release June 28, gcc 2.96 (RH7.3)
Morten Hulden
