[GRASS5] [bug #939] (grass) d.barscale ignores PROJ_UNITS
Glynn Clements glynn.clements at virgin.net
Mon Mar 4 15:11:00 EST 2002
Glynn Clements wrote:
> > Ideally, d.barscale should generate scale bars in a number of units,
> > which the user may specify.  That is, my map units may be meters, but
> > folks in the U.S. often want feet/yard/mile scales.
> That was basically my line of thought. It shouldn't be too hard to
> implement; just select a different "scales" table.
d.barscale now has a "-f" switch to select feet/miles instead of
metres.
Also, the bug with the x/y coordinates from the "at=..." option being
swapped has been fixed, and "d.barscale -m" will now invoke
"d.barscale at=..." once you confirm placement (so the command will
appear in the output of d.save, and the scale won't vanish if the
monitor is resized).
Glynn Clements <glynn.clements at virgin.net>
