[GRASS5] [bug #973] (grass) rgbcolors - d.save
Request Tracker grass-bugs at intevation.de
Thu Mar 21 05:22:29 EST 2002
this bug's URL: http://intevation.de/rt/webrt?serial_num=973
Subject: rgbcolors - d.save
Platform: Linux/Intel
Linux distro: Homemade
linux cpu: AMD (K6, ...)
Xwindows version: Xfree 3.3.6
Xwindows manager: KDE 2.x
TclTk version: tcl/tk 8.3
grass downloaded at: Trento site
grass binary for platform: I compiled the sources myself
grass sources source: no, I got a source code package from the server
c compiler name: gcc
I am using rgb-colors in d.area, i.e:
GRASS:~ > d.area map=vaf fillcolor="rgb(100 147  237)" linecolor=none
catnum=3101
Which works just fine.
But then I do a d.save;
GRASS:~ > d.save -o
d.area map=vaf fillcolor=rgb(100 147  237) linecolor=none catnum=3101  # 1
As you see, the "s are missing, if I try to reuse the line, I'll get:GRASS:~
 # 1
bash: syntax error near unexpected token `fillcolor=rgb(1'
It is of cource no really big deal to put in the "s, but i think d.save
should have done it for me...
Morten
-------------------------------------------- Managed by Request Tracker
