[GRASS5] The status of 5.0
Bernhard Reiter bernhard at intevation.de
Thu Mar 21 13:35:55 EST 2002
On Wed, Mar 20, 2002 at 01:11:54PM -0700, Roger Miller wrote:
> What should have been a simple task ended up taking several days and may
> still not be done, mostly because several of GRASS's vector modules
> (5.0pre2) didn't work right.
> I didn't have time to detail all of the problems as they came up, but I
> can list some of the problems were.  There were probably others that I
> don't remember.
Thanks for writing the report.
The development team tries to record each bug and follow up on it
when time permits.
> but has a lot of work been done on the vector modules since 5.0pre2?
GRASS is a huge application, a lot of work has gone into 5.0pre3.
Check the news file for changes between pre2 and pre3:
	http://grass.itc.it/grass5/source/NEWS.html
Apard from general improvements fixes to 10 vector modules are listed.
Name: not available
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20020321/14e5f32e/attachment.bin
