[GRASS5] A naive opinion on how grass *should* work
Glynn Clements glynn.clements at virgin.net
Fri May 3 14:42:14 EDT 2002
Carl Worth wrote:
>  > Yes; the default region is explicitly chosen by the user. Same for the
>  > current region. The only time that the current region is changed is if
>  > the user decides to change it.
> Except when the suer is just panning/zooming around a map and the
> region is being adjusted all the time. ;-)
Running d.zoom constitutes a decision to change the region. Changing
the region is what d.zoom does; it just does it visually rather than
through literal coordinates.
Glynn Clements <glynn.clements at virgin.net>
