[GRASS5] Re: [GRASS-CVS] CVS update: grass/src/raster/r.tiff
Glynn Clements glynn.clements at virgin.net
Tue May 7 03:23:26 EDT 2002
Markus Neteler wrote:
> In general - do we want to maintain r.in.tiff when r.in.gdal does more
> or less the same (eventually group file handling must be added explicitely
> for RGB, if needed)?
Unlike GDAL, r.in.tiff doesn't require a working C++ compilation
environment. TIFF is probably too important to impose any unnecessary
dependencies. Using tifftopnm -> r.in.p?m isn't adequate, as r.in.p?m
will ignore the .tfw file, and converting indexed (aka colourmapped,
paletted) images to true-colour destroys the underlying structure.
Glynn Clements <glynn.clements at virgin.net>
