[GRASS5] Re: [GRASS-CVS] CVS update: grass/src/mapdev/v.llabel
Markus Neteler neteler at itc.it
Thu May 9 04:35:40 EDT 2002
On Thu, May 09, 2002 at 08:55:08AM +0100, Glynn Clements wrote:
> [NB: I've committed the fix to the head.]
> Radim Blazek wrote:
> > 1) v.llabel map=pok
> > Error: value <all> out of range for parameter <type>
> >        Legal range: point,line,edge
> > 2) Was not commited to HEAD.
> > Sorry Roger, I don't want to discourage you, to contribute to grass,
> > but module should be probably run, before changes are commited,
> > and that all fixes in release branch MUST be commited to HEAD, is
> > obvious (I hope, am I right? - I never know what will be the future
> > of branches).
> In general, changes should be committed to the head first. Only once
> they've had sufficient testing should they be committed to the release
> branch.
> However, if the change is a simple fix for a definite bug (as is the
> case here), it can be committed to the head and to the release branch
> simultaneously.
Glynn,
would you mind to post (another time?) the cvs-sync-with-releasebranch
command line (I can't find your last mail on that any more)?
It was cvs -j something (to be invoked in HEAD, right)?
Thanks,
 Markus
