[GRASS5] compile short-cut?
Glynn Clements glynn.clements at virgin.net
Wed May 15 17:00:36 EDT 2002
Russell Nelson wrote:
> Is there any way to short-cut the compile process?
Yes; use "gmake5". This script is installed by "make install";
alternatively you can run the copy in the bin.<arch> directory, but
you must use a full pathname, e.g.
	`pwd`/bin.i586-pc-linux-gnu/gmake5 src/libes/gis
OTOH, there's an alternate build mechanism in the "mk" subdirectory;
see mk/README for (brief) details. This is simpler to understand than
the gmake5 build system.
Glynn Clements <glynn.clements at virgin.net>
