[GRASS5] [bug #1061] (grass) Re: S-57 Warning
Request Tracker grass-bugs at intevation.de
Fri May 24 16:31:08 EDT 2002
this bug's URL: http://intevation.de/rt/webrt?serial_num=1061
Request Tracker wrote:
> Hi Frank,
> Noticed this warning:
> F:\fme\foundation\formats\s57\s57rd.cpp(568) : warning C4018: '<' :
> signed/unsigned mismatch
> Fixed it by updating the line to this:
>    for( iAttr = 0; iAttr < int(oAttrList.entries()); iAttr++ )
> Other than that, this is in teh biuld that will be made shortly -- thanks!
Dale,
I have applied this change upstream.
Best regards,
--- Headers Follow ---
>From warmerdam at pobox.com  Fri May 24 22:30:53 2002
Return-Path: <warmerdam at pobox.com>
Delivered-To: grass-bugs at lists.intevation.de
Received: from mail.intevation.de (aktaia [212.95.126.10])
	by lists.intevation.de (Postfix) with ESMTP id 19ADF139C5
	for <grass-bugs at lists.intevation.de>; Fri, 24 May 2002 22:30:53 +0200 (CEST)
Received: from sabre.velocet.net (sabre.velocet.net [216.138.209.205])
	by mail.intevation.de (Postfix) with ESMTP id CA71C1B6D6
	for <grass-bugs at intevation.de>; Fri, 24 May 2002 22:30:51 +0200 (CEST)
Received: from pobox.com (H156.C195.tor.velocet.net [216.138.195.156])
	by sabre.velocet.net (Postfix) with ESMTP id 106B1137FCB
	for <grass-bugs at intevation.de>; Fri, 24 May 2002 16:30:41 -0400 (EDT)
Message-ID: <3CEEA1EC.9050309 at pobox.com>
Date: Fri, 24 May 2002 16:26:20 -0400
Reply-To: warmerdam at pobox.com
User-Agent: Mozilla/5.0 (X11; U; Linux i586; en-US; rv:0.9.9) Gecko/20020313
X-Accept-Language: en-us, en
MIME-Version: 1.0
To: Request Tracker <grass-bugs at intevation.de>
Subject: Re: S-57 Warning
References: <HFEDJMCIBBBODENDNEHEIEECFHAA.dal at safe.com>
Content-Type: text/plain; charset=us-ascii; format=flowed
Content-Transfer-Encoding: 7bit
X-Spam-Status: No, hits=0.0 required=5.0 tests= version=2.20
X-Spam-Level:
-------------------------------------------- Managed by Request Tracker
