[GRASS5] Preparing 5.0.3 release
Markus Neteler
neteler at itc.it
Wed Aug 20 09:19:21 EDT 2003
On Thu, Aug 21, 2003 at 12:51:59AM +1200, Hamish wrote:
> > Some questions remain:
> > - what about the ps.map changes?
> grass/src/ps.map/ps.map/cmd/ps_fclrtbl.c
> bug fixes
> grass/src/ps.map/ps.map/cmd/do_labels.c
> bug-like fix
> grass/src/ps.map/ps.map/cmd/ps_map.c
> cosmetic bug fix
> grass/src/ps.map/scripts/demo[1,2,3,5,8,9].src
> "update them so they actually work"
OK, all files above sync'ed.
> > - r.transect changes?
> Yes. The version in 5.0.2- is broken & does not run. It also
> contained several options which don't exist in the code.
OK, sync'ed.
> other stuff that might be worth including:
> r.profile
> There was a bug where it would output the last position twice which
> hasn't been merged. Not very important.
OK, done.
> grass/src/mapdev/v.digit/node_lines.c
> mouse button instructions were wrong
OK
> src/display/d.geodesic/cmd/main.c
> fixes SegFault?
This is not clear to me.
> src/raster/r.fill.dir/ppupdate.c
> fixes SegFault. Works for me-- can someone else test please?
Stephan Holl has tested - fix works.
Sync'ed.
> Is everything working now for NVIZ and tk8.4?
Good question.
> The html list gives me a headache to look at..
Most of your fixes are sync'ed except the modules with
new features (I hope I got that right).
SUM: d.geodesic is unclear.
Markus
