[GRASS5] debugging of shared libs
moovida moovida at katamail.com
Fri Jun 6 08:19:17 EDT 2003
Some debugging related question:
I'm trying to update Sorokine's Java4grass work for Grass 5.x in linux Suse
8.2. I got into some troubles (since the source was written on Solaris) and
need to debug a shared library, which is called from Java through JNI. The C
- lib is compiled for sure with the debugging option, but when I call it with
ddd, I'm not able to see the source:
DDD: no source
/tmp/ccpQSO9i.s: No such file or directory
Has anyone any hint?
Thanks
Andrea
____________________________________________________________________________
University of Trento
Department of Civil and Environmental Engineering
Via Mesiano, 77 - Trento (ITALY)
Andrea Antonello
tel:  +393288497722
fax:  +390461882672
email:antonell at ing.unitn.it
