[GRASS5] debugging of shared libs
Bernhard Reiter bernhard at intevation.de
Fri Jun 6 09:33:34 EDT 2003
On Fri, Jun 06, 2003 at 02:19:17PM +0200, moovida wrote:
> Some debugging related question:
> I'm trying to update Sorokine's Java4grass work for Grass 5.x in linux Suse
> 8.2. I got into some troubles (since the source was written on Solaris) and
> need to debug a shared library, which is called from Java through JNI. The C
> - lib is compiled for sure with the debugging option, but when I call it with
> ddd, I'm not able to see the source:
> DDD: no source
> /tmp/ccpQSO9i.s: No such file or directory
There is a way in gdb to give extra paths for sources
over options. Maybe you find something in the documentation.
Name: not available
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20030606/c35ee318/attachment.bin
