[GRASS5] coding a little bit of image processing
Yann st027364 at ait.ac.th
Tue May 27 11:42:03 EDT 2003
Hello,
i would like to code some little bit of image processing (say NDVI for
example) and later on make it available into the main gui
(UserDIP=>NDVI=>bandselection/openfile1&2)
I found r.example and i am planning to study it (yes i am a newbie!),
but are there some better way to do it coming from the new things of
grass51.
If yes, is there anyone who could suggest/submit some simple programming
framework adapted to 5.1.xx that i could study.
The gui thing will come after that first step is successful.
Thank you,
Yann
