[GRASS5] coding a little bit of image processing
Markus Neteler neteler at itc.it
Wed May 28 10:02:15 EDT 2003
On Tue, May 27, 2003 at 10:42:03PM +0700, Yann wrote:
> Hello,
> i would like to code some little bit of image processing (say NDVI for
> example) and later on make it available into the main gui
> (UserDIP=>NDVI=>bandselection/openfile1&2)
> I found r.example and i am planning to study it (yes i am a newbie!),
> but are there some better way to do it coming from the new things of
> grass51.
> If yes, is there anyone who could suggest/submit some simple programming
> framework adapted to 5.1.xx that i could study.
Well, there is nothing really prepared. I think we need a sort
of Programming HOWTO, move the Latex Progman stuff into the
C code (doxygen) and so on.
Meanwhile you may just take 5.1 and see how it is done.
There are plenty of things to do there, but it's a starting
point.
Markus
