[GRASS5] r.terraflow
Laura Toma ltoma at bowdoin.edu
Thu Sep 18 15:11:44 EDT 2003
I downloaded grass-5.0.3rc2 and looked at the code in
src.contrib.DUKE/r.terraflow/ and there dont seem to be many changes:
$diff grass-5.0.3rc2/src.contrib/DUKE/r.terraflow/Gmakefile
~/r.terraflow.1.5/Gmakefile
45c45
< CFLAGS += -Wall -I$(IOSTREAM_INC)
 > CFLAGS += -Wall -I$(IOSTREAM_INC) -Wno-deprecated
~/r.terraflow.1.4/Gmakefile
59,60c59,60
<            -mkdir $(OBJARCH)/FLOAT ; true
<            -mkdir $(OBJARCH)/SHORT ; true
Are these all the fixes?  Where is the patch located? How can i look at
the fixes? Do I need to compile grass to see them?  Does r.terraflow get
compiled when installing grass, or,  one has to run Gmakefile in
r.terraflwo directory (this is the way it used to be) ?
thanks,
Laura
Glynn Clements wrote:
>Laura Toma wrote:
>>I am not sure I understand what the problem is.. This is the update
>>about r.terraflow:
>>-version 1.4 does not compile with gcc3.2.
>>-version 1.5 does.
>>-functionality is the same, some files in 1.5 have changed to gcc3.2
>>requirements
>>-the only difference in the Gmakefiles  is that 1.5 contains the
>>additional compile flag Wno-deprecated
>It appears that Hamish made the patch between the version in GRASS CVS
>and the 1.5 tarball. The CVS version includes some fixes to the
>original version (presumably 1.4), so his patch would effectively undo
>those fixes.
>What should be done is to produce a patch between the unmodified 1.4
>and 1.5 versions, then to apply that patch to the CVS version. That
>should produce a version which includes both the fixes and the
>1.4->1.5 changes.
