[GRASS5] r.terraflow
Sun Sep 21 03:43:48 EDT 2003
> Laura Toma wrote:
> > I am not sure I understand what the problem is.. This is the update
> > about r.terraflow:
> > -version 1.4 does not compile with gcc3.2.
> > -version 1.5 does.
> > -functionality is the same, some files in 1.5 have changed to gcc3.2
> > requirements
> > -the only difference in the Gmakefiles  is that 1.5 contains the
> > additional compile flag Wno-deprecated
> It appears that Hamish made the patch between the version in GRASS CVS
> and the 1.5 tarball. The CVS version includes some fixes to the
> original version (presumably 1.4), so his patch would effectively undo
> those fixes.
Yes, that is correct.
Hamish
