[GRASS5] r.terraflow
Sun Sep 21 03:58:42 EDT 2003
> What should be done is to produce a patch between the unmodified 1.4
> and 1.5 versions, then to apply that patch to the CVS version. That
> should produce a version which includes both the fixes and the
> 1.4->1.5 changes.
Here is a diff between r.terraflow versions 1.4 and 1.5 as downloaded
from Laura's webpage:
http://bambi.otago.ac.nz/hamish/grass/r.terraflow1.4_1.5.diff
http://www.cs.duke.edu/geo*/terraflow/r.terraflow.1.4.tar.gz
http://www.cs.duke.edu/geo*/terraflow/r.terraflow.1.5.tar.gz
[note "r.terraflow/" moved to "r.terraflow.1.4/" for diff]
Hamish
