[GRASS5] Licensing problem
Bernhard Reiter bernhard at intevation.de
Thu Sep 25 11:45:31 EDT 2003
On Tue, Sep 23, 2003 at 12:07:40AM +0100, Glynn Clements wrote:
> Bernhard Reiter wrote:
> > Markus by accident found out that there is a potential
> > licensing problem left that we need to deal with.
> > It probably affects all versions of GRASS
> > and especially the upcoming 5.0.3.
> > We need to:
> > 	a) replace ./src/include/color.h
> > 	Method 1: Check if there once was a public domain version
> > 	with this file and use that one.
> > 	Method 2:
> > 	The contents itself a simple.
> > 	Glynn: Would it make sense to rewrite this and
> > 	reshuffle the stuff with colors.h into one file anyway?
> > 	If yes, would you be willing to do it?
> Method 3:
> Delete src/include/color.h and replace its sole use in
> src/ps.map/ps.map/cmd/vector.h with a local definition for the only
> portion which is actually used:
> 	typedef	struct {
> 		unsigned short r, g, b;
> 	} RGB;
Sound good to me if "color.h" is not included somewhere else.
Can you make the change Method 3 then?
> I'm fairly sure that the above struct definition doesn't qualify as an
> "original work".
I agree.
Name: not available
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20030925/1b488266/attachment.bin
