[GRASS5] New tcltkmenu
Sjors jkwast at freeler.nl
Sat Apr 17 09:08:29 EDT 2004
Thanks Andrea, it worked just fine. After a quick glance I'm most happy,
nice work Michael.
We should be putting this in cvs and snapshot.
Greetings Sjors
Andrea Antonello wrote:
>I can only say WOW!
>I tried to install it (3,5 minutes) and it is relly really nice work!
>I guess your files are somehow corrupted, I attach the README installation
>part.
>TO INSTALL:
>1. Quit GRASS
>2. Backup your current $GISBASE/tcltkgrass directory (just to be safe) by
>renaming it $GISBASE/oldtcltkgrass.
>3. Copy the /tcltkgrass directory provided here to your $GISBASE (GRASS53 or
>GRASS5) directory. (It is possible that you may need to adjust permissions
>for the tcltk scrips in the $GISBASE/tcltkgrass/script directory to make sure
>that users have execute permissions--hopefully not necessary).
>4. Copy the scripts in the directory /add2scripts to your $GISBASE/scripts
>directory. (It is possible that you may need to adjust permissions for the
>scripts to make sure users have execute permissions--hopefully not
>necessary).
>5. Restart GRASS and tcltkgrass.
>My compliments,
>Andrea
>On Saturday 17 April 2004 11:41, Sjors wrote:
>>Hi,
>>If downloaded the package with the new TclTk menu from Michael Barton at
>>http://www.public.asu.edu/~cmbarton/grass.htm
>><http://www.public.asu.edu/%7Ecmbarton/grass.htm>
>>to play around with.  I untarred it etc, but the ReadMe.txt is binary or
>>something, at least text viewers can't read it. How do I install this? Is
>>it updated to cvs yet? If so, if I update from cvs is it automatically
>>installed?
>>Greetings Sjors
>>_______________________________________________
>>grass5 mailing list
>>grass5 at grass.itc.it
>>http://grass.itc.it/mailman/listinfo/grass5
