[GRASS5] Re: grass5 digest, Vol 1 #1033 - 6 msgs
    Michael Barton
    michael.barton at asu.edu
    Mon Feb  9 11:42:30 EST 2004
Glynn,
It is great news that you have GRASS 5.3 compiling successfully for
Cygwin. I have several questions.
1. In the list of Cygwin components you list has having installed (in
section of copied message below) are opengl and sunrpc. Are these only
necessary for compiling Cygwin or are they also needed for the
binaries? I ask because there is an old version of sunrpc on the
WinGRASS web page, but the binaries installation instructions ignore it.
2. Can GRASS 5.3 open monitors via the tcltk menu or is it still
necessary to do this from the command line using d.mon?
3. If GRASS 5.3 works with tcltk 8.3.4, does that mean that it works
with the Cygwin version of tcltk or is it still necessary to install a
separate version?
Thanks for your time and help.
Michael
On Monday, February 9, 2004, at 04:01  AM, grass5-request at grass.itc.it
wrote:
> Done that; NVIZ still works.
> -r-xr-xr-x    1 root     root       749892 Mar 28  2002 libtcl8.3.a*
> -r-xr-xr-x    1 root     root       985818 Mar 28  2002 libtk8.3.a*
> fb69cc3342aa19f3fdb709738f6055e7  libtcl8.3.a
> 4e60b25c070637250f52aa13d5fcdc47  libtk8.3.a
> From:
> 2983750b94c52b8a5ce1aa3e39e54e45  xtcltk-8.3.4-CYGWIN.tar.gz
>>> Upon giving the above command, an empty (black) Windows command-line
>>> window appeared; the title bar contained the name of the NVWISH2.2
>>> program. The message
>>> ---Type <return> to continue, or q <return> to quit---
>>> then appeared in the terminal where NVIZ was started and on pressing
>>> return, the segmentation fault happened.
>>> What do the two question marks and empty brackets mean? Do the
>>> provided
>>> xtcltk libaries have debugging information? Does anything else need
>>> to be
>>> compiled with debugging turned on?
> The xtcltk 8.3.4 libraries don't have debug info, but they weren't
> compiled with -fomit-frame-pointer, so you should still get a
> backtrace, and functions which are from the NVIZ source code can be
> debugged.
> Although, if I run NVWISH2.2 under gdb, I get a segfault in libXext,
> but not if I run it directly (with identical arguments).
> FWIW, the relevant Cygwin components are:
> XFree86-bin-4.2.0-3.tar.bz2
> XFree86-xserv-4.2.0-37.tar.bz2
> binutils-20030307-1.tar.bz2
> cygwin-1.3.22-1.tar.bz2
> gcc-2.95.3-5.tar.bz2
> gdb-20030303-1.tar.bz2
> opengl-1.1.0-6.tar.bz2
> sunrpc-4.0-1.tar.bz2
> zlib-1.1.4-1.tar.bz2
> Glynn Clements <glynn.clements at virgin.net>
______________________________
Michael Barton, Professor & Curator
Department of Anthropology
Arizona State University
Tempe, AZ  85287-2402
USA
voice: 480-965-6262; fax: 480-965-7671
