[GRASS5] [bug #2493] (grass) libX11.dll
Request Tracker grass-bugs at intevation.de
Fri Jun 18 14:34:04 EDT 2004
this bug's URL: http://intevation.de/rt/webrt?serial_num=2493
Subject: libX11.dll
Platform: WindowsNT/2000/XP
grass obtained from: Other (CDROM etc)
grass binary for platform: Downloaded precompiled Binaries
GRASS Version: 5.7
This application has failed to start because libX11.dll wqs not found. Re-installing the application may fix this problem.
I did this may times but the result is the same.
-------------------------------------------- Managed by Request Tracker
