[GRASS5] [bug #2493] (grass) libX11.dll
Glynn Clements glynn.clements at virgin.net
Fri Jun 18 16:24:34 EDT 2004
Request Tracker wrote:
> Subject: libX11.dll
> Platform: WindowsNT/2000/XP
> grass obtained from: Other (CDROM etc)
> grass binary for platform: Downloaded precompiled Binaries
> GRASS Version: 5.7
> This application has failed to start because libX11.dll wqs not found.
> Re-installing the application may fix this problem.
> I did this may times but the result is the same.
Cygwin's XFree86 packages must be installed, and /usr/X11R6/bin (the
directory where libX11.dll resides) must be present in $PATH.
Glynn Clements <glynn.clements at virgin.net>
