[GRASS5] can't get 5.7 to get past ./configure
Paul Kelly paul-grass at stjohnspoint.co.uk
Sun Mar 7 06:47:35 EST 2004
On Sun, 7 Mar 2004, Jeff D. Hamann wrote:
> when I attempt to run make, I get,
> $ make
> "./include/Make/Grass.make", line 235: Missing dependency operator
> "./include/Make/Grass.make", line 308: Need an operator
> "Makefile", line 51: Missing dependency operator
> "Makefile", line 53: Need an operator
> make: fatal errors encountered -- cannot continue
I should have said also that the quick solution is probably to use GNU
make---if you proceed further into the compilation you will probably come
across other Makefiles that require GNU make anyway.
Paul
