[GRASS5] strange behaviour in command line
Glynn Clements glynn.clements at virgin.net
Sun Mar 7 14:56:37 EST 2004
Jeff D. Hamann wrote:
> I've been trying to type some longer commands in grass5.3 and have been
> running to wrapping when I get to about 30 or 40 characters, the line
> terminates and I can't move my cursor back to the beginning of the line.
> This doesn't happen in other programs, just grass. I thought I might have
> an older form of the cvs repos, so I updated and recompiled, but it still
> happens.
Are you referring to the GRASS shell? That is just a normal shell
(bash, csh etc, depending upon $SHELL).
Does it happen if you start GRASS non-interactively by specifying the
complete path to the mapset directory on the command-line?
Glynn Clements <glynn.clements at virgin.net>
