[GRASS5] Let's release 5.4 asap
Lorenzo Moretti lorenzo.moretti at bologna.enea.it
Fri Oct 1 08:40:42 EDT 2004
Hello Paul
On Fri, 1 Oct 2004, Paul Kelly wrote:
>This is already the case I suppose. So by that logic releasing 5.4.0
>now would make sense.
>The one big thing I would like to change is to make the alternate
>build mechanism the default for 5.4.0. That will require a few
>changes to the r.terraflow makefile. We can always recommend OS X
>users to use --enable-shared=no with 5.4 for now.
OK for OS X users: this is possible. It's OK if the OS X version has
static lib. Now last 5.3cvs is very stable on OS X. The true goal is
Grass 5.7: many OS X users already use the 5.7 version.
Bye
________________________________________________________________________
||      Lorenzo Moretti        e-mail: lorenzo.moretti at bologna.enea.it
||/|/|  ENEA prot/idr          Web: http://wwwamb.bologna.enea.it/
||   |  via Don Fiammelli, 2   FTP: ftp://ftpamb.bologna.enea.it/ (ris.)
~~~~~~  40128 BOLOGNA - ITALY  Ph: +39-0516098086  Fax: +39-0516098131
