[GRASS5] Re: [GRASSLIST:4462] fixes for recent problems in tcltkgrass for GRASS 5.3
Glynn Clements glynn.clements at virgin.net
Mon Oct 4 16:36:35 EDT 2004
Michael Barton wrote:
> Due to changes in the GRASS input parsing system, a few tcltkgrass commands
> no longer worked correctly. I *think* (and hope) that I found all the few
> instances and have fixed them. I just committed these fixes to the CVS.
The problems relate to changes in tcltkgrass, not libgis.
> This is an additional reason to separate the 5.3 build from 5.7. Because
> both 5.3 and 5.7 share the same code for input parsing fix to make this work
> much better under 5.7 broke input parsing for a few cases in 5.3 where it
> had worked fine before.
Nothing related to command-line parsing is shared between 5.3 and 5.7.
5.7 has its own version of d.m, tcltkgrass and parser.c.
Glynn Clements <glynn.clements at virgin.net>
