[GRASS5] Re: [GRASSLIST:4463] Re: fixes for recent problems in tcltkgrass for GRASS 5.3
Glynn Clements glynn.clements at virgin.net
Mon Oct 4 16:56:45 EDT 2004
Glynn Clements wrote:
> > Due to changes in the GRASS input parsing system, a few tcltkgrass commands
> > no longer worked correctly. I *think* (and hope) that I found all the few
> > instances and have fixed them. I just committed these fixes to the CVS.
> The problems relate to changes in tcltkgrass, not libgis.
More precisely, I suspect that it's due to this change to gui.tcl:
	revision 1.21
	date: 2004/08/04 00:55:26;  author: hamish;  state: Exp;  lines: +3 -3
	fix text entries with whitespaces in Tcl menus
Specifically, this part:
	@@ -727,7 +727,7 @@
	     switch [$path cget -text] {
	         Run {
	             if {$button == 1} {
	-                set name [eval concat $cmd]
	+                set name [concat $cmd]
	                 set see [expr {[lindex $cmd 0] == "g.manual"} ? 0 : -1]
	             } elseif {$button == 2} {
	                 set name "g.manual [lindex $root 0]"
Using "eval concat $cmd" would split list items into multiple words,
while "concat $cmd" will preserve boundaries.
	% set cmd "foo bar {baz baz}"
	% foreach word $cmd {puts $word}
	foo
	bar
	baz baz
	% set name [eval concat $cmd]
	% foreach word $name {puts $word}
	foo
	bar
	baz
	baz
	% set name [concat $cmd]
	foo
	bar
	baz baz
Actually, the existing version is equivalent to just "set name $cmd".
	% set name $cmd
	foo
	bar
	baz baz
The change causes it to correctly interpret arguments which contain
spaces but, as a side-effect, it doesn't handle commands which contain
spaces.
It should probably be:
	set prog [lindex $cmd 0]
	set args [lrange $cmd 1 end]
	set name [eval concat $prog [list $args]]
This will split the command but not the arguments.
Glynn Clements <glynn.clements at virgin.net>
