[GRASS5] Solaris9 test of 5.4
Gordon Keith gordon.keith at csiro.au
Tue Oct 26 18:09:30 EDT 2004
On Tue, 26 Oct 2004 17:44, Glynn Clements wrote:
> Gordon Keith wrote:
> > It would be nice if grass was also a simple configure; make; make
> > install. If configure would look for postgress in /usr/local/pgsql and
> > include /usr/ sfw/{include,lib} on solaris it would be good.
> The configure script used to autodetect directories; we took that
> feature out because it tended to find things which broke the build,
> making it impossible for some users to build GRASS.
OK, sounds reasonable.
I still think ./configure; make; make install should work inmost cases, at
least for a stable release (5.4).
Currently there seems to be two problems:
1) you need to create and use a separate build directory
2) postgres puts it's bits in /usr/local/pgsql instead of /usr/local
I know nothing about how to fix 1 but would it be possible to create a default
build directory and use it unless a switch is provided (eg --build-dir=)
With 2 it would be good if either the default build was --without-postgres or
configure looked for postgres files under /usr/local/pgsql. I suspect the
former may be cleaner. If you have to specify postgress include and lib
switches then having to provide --with-postgress makes sense.
Just my $0.02 as someone who only installs grass occassionaly and would really
like to be able to just install it without having to figure out all the
configure switches first.
Regards
Gordon
Gordon Keith
Programmer/Data Analyst
Marine Acoustics
CSIRO Marine Research
http://www.marine.csiro.au
The world and everything in it that people desire is passing away;
but he who does the will of God lives for ever.
  -- 1 John 2:17
