[GRASS5] [bug #3160] (grass) r.support build error
Wed Apr 27 18:39:13 EDT 2005
Markus Neteler wrote:
> > > /home/pingwin/src/grass6/dist.i686-pc-linux-gnu/etc/modcats
> > > OBJ.i686-pc-linux-gnu/modcats.o -lgrass_gis -lgrass_datetime -lz    -lgrass_edit
> > >  -lm  -lz
> > > /usr/bin/ld: warning: libgrass_vask.so, needed by
> > > /home/pingwin/src/grass6/dist.i686-pc-linux-gnu/lib/libgrass_edit.so, not
> > > found (try using -rpath or -rpath-link)
> > Right. As it says, we should be using -rpath-link. I thought that we
> > were.
> > The correct switches are already present in LD_SEARCH_FLAGS, but we
> > don't appear to be using that.
> ... if you know how to fix that, please apply to the CVS.
Done.
BTW, I've noticed that LDFLAGS includes $(PQLIBPATH), although it
doesn't belong there.
