[GRASS5] [bug #3160] (grass) r.support build error
Markus Neteler neteler at itc.it
Wed Apr 27 18:57:04 EDT 2005
On Wed, Apr 27, 2005 at 11:39:13PM +0100, Glynn Clements wrote:
> Markus Neteler wrote:
> > > > /home/pingwin/src/grass6/dist.i686-pc-linux-gnu/etc/modcats
> > > > OBJ.i686-pc-linux-gnu/modcats.o -lgrass_gis -lgrass_datetime -lz    -lgrass_edit
> > > >  -lm  -lz
> > > > /usr/bin/ld: warning: libgrass_vask.so, needed by
> > > > /home/pingwin/src/grass6/dist.i686-pc-linux-gnu/lib/libgrass_edit.so, not
> > > > found (try using -rpath or -rpath-link)
> > > Right. As it says, we should be using -rpath-link. I thought that we
> > > were.
> > > The correct switches are already present in LD_SEARCH_FLAGS, but we
> > > don't appear to be using that.
> > ... if you know how to fix that, please apply to the CVS.
> Done.
Thanks.
> BTW, I've noticed that LDFLAGS includes $(PQLIBPATH), although it
> doesn't belong there.
Should it be fixed by removing it or in a different way?
Markus
