[GRASS5] [bug #2927] (grass) d.what.vect - broken pipe
Radim Blazek blazek at itc.it
Mon Jan 24 04:23:20 EST 2005
Request Tracker wrote:
> this bug's URL: http://intevation.de/rt/webrt?serial_num=2927
> Subject: d.what.vect - broken pipe
> Platform: GNU/Linux/i386
> grass obtained from: Mirror of Trento site
> grass binary for platform: Compiled from Sources
> GRASS Version: grass-6.0.cvs_src_snapshot__2005_01_15
> d.what.vect in most cases quits displaying "Broken pipe" info.
> I have written the proceure in detail. Sorry if I overdosed but had a good intention :).
> 1. Digitized a new vector line layer consisted of one short line. A database with one integer column was created in the v.digit Settings->Table menu.
> 2. Closed v.digit. Topology built fine.
> 3. Displayed on x0.
> 4. First d.what.vect went fine no matter how brutally I clicked and where.
> 5. Closed d.what.vect.
> 6. Started d.what.vect again. First click - no response. Next click - "Broken pipe" and exit.
> 7. Each folowing d.what.vect behaved the same.
> 8. Quiting Grass or even the X server didn't help. Rebooting did. But the problem was back after invoking d.what.vect for the second time.
> 9. Also some zooming and uzooming helped though not always. But again the story began after calling d.what.vect for a second time.
> Maciek
> -------------------------------------------- Managed by Request Tracker
> grass5 mailing list
> grass5 at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass5
The GUI mode does not work on all platforms, you have to use '-x'
flag.
Radim
