[GRASS5] [bug #2927] (grass) d.what.vect - broken pipe
Maciek Sieczka werchowyna at pf.pl
Mon Jan 24 11:26:13 EST 2005
> Request Tracker wrote:
>> this bug's URL: http://intevation.de/rt/webrt?serial_num=2927
>> Subject: d.what.vect - broken pipe
>> Platform: GNU/Linux/i386
>> grass obtained from: Mirror of Trento site
>> grass binary for platform: Compiled from Sources
>> GRASS Version: grass-6.0.cvs_src_snapshot__2005_01_15
>> d.what.vect in most cases quits displaying "Broken pipe" info.
Radim Blazek <blazek at itc.it> wrote:
> The GUI mode does not work on all platforms, you have to use '-x'
> flag.
Hamish via RT <grass-bugs at intevation.de> wrote
> work-around: use text mode. d.what.vect -x
I have just checked that d.what.vect in GUI mode works MUCH better in
grass57_exp_2004_12_18 built from source (though still fails from time to
time diplaying the same "Broken pipe" info). Also the bug in v.digit
http://intevation.de/rt/webrt?serial_num=2926 attacks less often in that
grass57. Maybe this could be a clue how to fix it?
My platform is Mandrake 10.1, Kde 3.2, gcc 3.3.4 (I have tried 3.4.1 but it
fails e.g. with grass54, hdf4), kernel 2.4.27-0.pre2.1mdk (defult 2.6.8
behaves spooky sometimes). Could some of these components be guilty? If I
went back to Mandrake 9.2 could it better? I realize you might not be able
to guess that far, but if you have an idea - please let me know.
Cheers
Maciek
