[GRASS5] g.copy error message
Radim Blazek blazek at itc.it
Wed Jan 26 04:10:51 EST 2005
otto dassau wrote:
> Dear list,
> copying maps from PERMANENT to current mapset fails using the same name:
> g.copy vect=roads,roads
> map roads already exist in mapset PERMANENT
> if this is intended, maybe the error message could be extended to sth, like:
> map roads already exist in mapset PERMANENT, please add target mapset to map
> or sth. else.
>  thanks
>    Otto
I have fixed it, now it checks if the map exist only in current mapset.
Radim
