[GRASS5] running grass on macosx
Mon Jun 20 02:38:14 EDT 2005
> i have looked hi and low but i can't find why this happened.
> i have read the tutorial and many other tips and emails that i found
> using google. there is so much info out there that it is very complex.
> i  installed gdal, proj, R-2.1.0<failed>
> i also tried the latest from cvs but ran into too many files not found
> but are installed<jpeg,tiff,,png,postgres,fftw>
> i have macosx 10.4.1 on tibook using grass61cvs...same with grass60
Are you using the Lorenzo Moretti binaries, the MaxOSX binaries, or
something you compiled yourself?
> GRASS 6.0.0 (spearfish):~ > NavGetReply failed, -128
> using default visual which is TrueColor
> ncolors: 16777216
> Graphics driver [x0] started
> ERROR: vector map <roads> not found
what does:
"g.list rast"
at the GRASS prompt show?
Hamish
