[GRASS5] Ps.map wish/question
Tue May 17 04:35:49 EDT 2005
roger at spinn.net wrote:
> Quoting Michael Barton <michael.barton at asu.edu>:
> I use ps.map regularly.  As it is now ps.map scripts fairly easily.
> The PNG driver can be used to get hard copy output that exercises all of the
> limited capabilities of the d.* commands.  There really isn't much point to
> using ps.map just to do what the d.* commands can do.
ps.map will produce much better results for vectors.
