[GRASS5] Ps.map wish/question
roger at spinn.net roger at spinn.net
Mon May 16 17:10:59 EDT 2005
Quoting Michael Barton <michael.barton at asu.edu>:
I use ps.map regularly.  As it is now ps.map scripts fairly easily.
The PNG driver can be used to get hard copy output that exercises all of the
limited capabilities of the d.* commands.  There really isn't much point to
using ps.map just to do what the d.* commands can do.
Roger Miller
> Maybe I missed it in my cursory look at the ps.map docs, but it seems like
> some d.* command options are a subset of the ps.map commands. I assume that
> people using ps.map would continue to use the richer ps.map commands (i.e.,
> not replace ps.map commands, but have ps.map also recognize some d.*
> commands).
> I was thinking that if ps.map also would read relevant d.* commands it would
> be more easily scriptable.
> Michael
> ______________________________
> Michael Barton, Professor of Anthropology
> School of Human Evolution and Social Change
> Arizona State University
> Tempe, AZ  85287-2402
> USA
> voice: 480-965-6262; fax: 480-965-7671
> www: http://www.public.asu.edu/~cmbarton
>> From: Glynn Clements <glynn at gclements.plus.com>
>> Date: Sun, 15 May 2005 12:18:08 +0100
>> To: Michael Barton <michael.barton at asu.edu>
>> Cc: grass5 developers list <grass5 at grass.itc.it>
>> Subject: Re: [GRASS5] Ps.map wish/question
>> Michael Barton wrote:
>>> I haven?t used ps.map. It seems like a very useful module, but one that is
>>> fairly complex to use. While looking though the docs, however, it became
>>> apparent that it performs the same kind of display functions (to
>>> paper/postscript file) as many of the d.* modules do (to the display
>>> monitor)--and does a number of other special functions like setting paper
>>> size and margins of course. However, it uses a slightly different syntax to
>>> perform equivalent functions. E.g., rast [mapname] for ps.map vs. d.rast
>>> [mapname] for screen display.
>>> This led me wonder if it would be difficult to have ps.map accept as an
>>> alternative syntax, the d.* commands for which it has equivalent functions.
>>> D.vect (vareas, vlines, vpoints), d.rast (rast), d.barscale (scalebar),
>>> d.grid (grid or geogrid) seem easily apparent. There might be reasonably
>>> straightforward translation for additional d.* commands like d.frame and
>>> d.graph also.
>>> If this could be done, then either a set of normal GRASS commands?or even
>>> nicer, the file produced by d.save?could be piped to ps.map to make nice
>>> postscript output.
>>> How feasible would this be?
>> It would be simple enough to define aliases for existing ps.map
>> commands. However, users would probably be confused by the significant
>> differences between the ps.map commands and their d.* counterparts.
> grass5 mailing list
> http://grass.itc.it/mailman/listinfo/grass5
