[GRASS5] GRASS 6 automatic start
Ricardo Armas rgoncalves at criticalsoftware.com
Fri May 20 07:35:31 EDT 2005
Hello everyone.
I have some problems with GRASS 6. Sometimes, even after a couple of tries,
GRASS does not start.
Can anyone explain me what is going on? Is it normal?
I tried to install it in a different computer but the same is happening.
Thanks in advance.
Ricardo
DISCLAIMER: This message may contain confidential information or privileged material and is intended only for the individual(s) named. If you are not a named addressee and mistakenly received this message you should not copy or otherwise disseminate it: please delete this e-mail from your system and notify the sender immediately. E-mail transmissions are not guaranteed to be secure or error-free as information could be intercepted, corrupted, lost, destroyed, arrive late or incomplete or contain viruses. Therefore, the sender does not accept liability for any errors or omissions in the contents of this message that arise as a result of e-mail transmissions. Please request a hard copy version if verification is required. Critical Software.
URL: http://lists.osgeo.org/pipermail/grass-dev/attachments/20050520/80301e58/attachment.html
