[GRASS5] Code Formatting
Sat Apr 22 08:47:10 EDT 2006
[indent rules]
> > > Any objections to changing:
> > > 	-bli1	->	-bli0
> > > 	-br	->	-bl
> > translation:
> >   '{' comes on next line after if,for etc instead of "if {"
> >   Structs, functions already do this (-bls)
> That's the -br -> -bl change.
> Changing -bli1 -> -bli0 means that braces are aligned with the command
> rather than being an extra space in, i.e.
>         if (...)
> rather than:
>         if (...)
> Having braces aligned makes it easier to do manual alignment, as
> everything is then aligned to a multiple of 4 columns. It's also
> easier in terms of configuring Emacs' auto-formatting, which expects
> everything to be specified as multiples of the indentation step.
Oh, -bli1 is definitely wrong in that case. From my reading of the
indent man page, I thought with -br a -bli3 would do "if()   {", hence
the -bli1. If using -bl instead of -br it should surely be -bli0.
Hamish
