[GRASS-dev] WxPython prototype GRASS GUI. Version 2
Yann Chemin ychemin at gmail.com
Mon Aug 7 22:21:48 EDT 2006
Thanks Glynn !
It works well.
here are the modifications:
in gism.py replace:
("Map calculator", "Map calculator", self.runMenuCmd, "r.mapcalc"),
with this:
("Map calculator", "Map calculator", self.runMenuCmd, "mapcalc_gparser.sh"),
and add the Glynn file attached (mapcalc_gparser.sh) to the py_gm directory.
it opens a r.mapcalc dialog box where one can enter equations.
Yann
On 08/08/06, Yann Chemin <ychemin at gmail.com> wrote:
> nice!
> ok, i'll try.
> thanks,
> Yann
> On 08/08/06, Glynn Clements <glynn at gclements.plus.com> wrote:
> > Yann Chemin wrote:
> > > Sorry to ask this new bie question, but you mean that the front-end
> > > should be a file called from the GUI and this front-end will somehow
> > > launch r.mapcalc, don't you?
> > Yes. The front-end would be a g.parser script with one option,
> > expression=, and it would invoke r.mapcalc on that expression.
> > Unlike r.mapcalc, a script which uses g.parser will accept all
> > G_parser() options, e.g. --interface-description.
Type: application/x-sh
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20060808/8653a5f6/mapcalc_gparser.sh
